Re: 300 wont fire
Posted by makin'hay on April 18, 2009 at 14:33:24 from (69.95.141.44):
In Reply to: Re: 300 wont fire posted by peculiar farmer on April 18, 2009 at 13:04:36:
I"ve got the correct firing order, and at this point I dont think I could be insulted if you tried! I appreciate ANY advice. I have checked TDC 3 times to make sure I am on comp. stroke, pulled cap, checked rotor position, checked plug wire position, 1-3-4-2 from radiator being #1. I also checked if #1 fires between timing marks and not before TDC. Spark is good. I did pull all plugs and they are dry. I do have gas in carb bowl and tank. Hmmm. Thanks
