Re: 300 wont fire
Posted by El Toro on April 18, 2009 at 16:20:05 from (64.12.116.73):
In Reply to: Re: 300 wont fire posted by makin'hay on April 18, 2009 at 15:39:33:
Hold your hand over the throat of the carburetor and see if you have good suction. You need good manifold vacuum to pull that fuel into the engine.
Good valve seating and adjustment, good rings and sleeves not worn will give good compression and vacuum. Hal
