Re: McCormick-Deering 10-20 runs but I can't hand crank s...
Posted by dave koenigsfeld on April 18, 2009 at 18:50:47 from (148.78.54.134):
In Reply to: Re: McCormick-Deering 10-20 runs but I can't hand crank s... posted by spiffy1 on April 18, 2009 at 18:30:07:
I really need to go check all of the plugs and the timing and reconfirm everything. Tubes are new and confirmed to be free flowing. The only thing that I did not witness was the motor man adjusting the throttle/timing rod so that I could retard the timing to kill the motor. Before that, we hand cranked the motor to start about 4 times. The engine has run about an hour and half total since first fire. How long should I run it to seat the rings?
I will reaaly work with the starting fluid/fuel and spark lever to find the sweet spot. It gets tiring fast when your by yourself!
Thanks for the help,
Dave
