Re: H starting/electrical problems
Posted by rvirgil_KS on April 19, 2009 at 07:30:34 from (204.120.9.86):
In Reply to: H starting/electrical problems posted by Minnesotan H on April 19, 2009 at 05:56:10:
Is it 6 volts or 12 volts?
6 volts should not use a resistor in series with the coil.
If 12 volts, a true 12 volt or "12 volt no external resistor required" coil does not use a resistor
If 12 volts with 6 volt coil resistor goes between coil and ignition switch. You should have about 6 volts on coil input with points closed.
Also, if positive ground the positive post of coil goes to distributor, if negative ground negative post goes to distributor.
Here's a chart that may help
