Re: International 460 - 3 point hitch. Always going up o...
Posted by Hugh MacKay on April 19, 2009 at 08:14:22 from (216.208.58.147):
In Reply to: International 460 - 3 point hitch. Always going up or down posted by ttiiggy on April 19, 2009 at 06:43:04:
ttiiggy: There are a set of spider gears in the hitch control valve that connect between draft control and hand control lever. Those gears are broken. I don't know if you can buy new spider gears.
I had this happen to a 560 around 1970, gears were available then but costly. I didn't use my hitch for plowing, so I changed the control valve out for a regular double-single action valve. Any control valve from a 230, 300, 400, 330, 350, 450, 240, 340, 460 or 560 will fit.
