Weights are bringing 50 cents to 1 dollar a pound, so the prices are not out of line. If you can get them for $35 each, buy as many as your pickup can carry.
Weights vs. fluid... On larger tires you can get far more weight from fluid than a reasonable number of iron weights.
A 13.6x38 tire, which is arguably one of the most common tire sizes due to the popularity of the H and M size tractors, holds 57 gallons of fluid for approximately 600lbs of ballast. (ballaststarDOTcom is my source of info)
That's equivalent to FOUR complete circles of weights PER TIRE.
A 20.8x38 tire holds 1500lbs of ballast. That's TEN circles of iron weights.
The break even point is on a Farmall Cub. An 8.3x24 tire holds 140lbs of fluid, and weights are roughly 140-150lbs each. Adding one set of weights is equivalent to filling the tires with fluid here.
You can get fluids that are non-corrosive, like beet juice or windshield washer fluid. But, think about this: It took 40-50-60 years of hard daily use for the calcium chloride to cause problems. The way we use these tractors nowadays, fluid in a good tube will last you as long as you care to have it last.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
