Posted by tonastoy on April 19, 2009 at 15:53:40 from (66.82.9.57):
hi. ive just spent the last year and half restoring my super h . it ran fine other than it was getting a little weak when i started the over haul project, i rebuilt the carb but i had trouble getting it started, it was starving for gas, but gas would run out of the carb when it wasnt running. took it apart again and it looked like the gasket on the bowl was slightly covering one of the ports in the center of the bowl, bought another kit and rebuilt it again , now it starts but i cant get it adjusted and it runs rich all the time no matter what i do, still has gas running out of the carb, buy a new float, try setting it to 1 3/8 inch even, still leaking gas. if i turn off the gas while its running it stops running rich . i can turn the high speed needle all the way in or three turns out and it doesnt make a difference. i took it out and tryed disking with it , part of the time it would run rich and blow black smoke and other times i had to run it with the choke out to keep it running.anybody have any ideas , ready to take the carb off and throw it in the river
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
