Re: FARMALL 460-DIES AFTER ABOUT AN HOUR OF MOWING PASTURE
Posted by El Toro on April 19, 2009 at 15:59:29 from (205.188.116.73):
In Reply to: FARMALL 460-DIES AFTER ABOUT AN HOUR OF MOWING PASTURE posted by NEWBINIA on April 19, 2009 at 09:02:42:
Use a volt meter across your battery terminals and with the engine at 1/2 throttle or better see what the charging voltage is. shouD be around 14 volts on it if its a 12 volt system. Could be the coil too. When ir quits running you need to check for to fire to your plugs ASAP before it has a chance to cool. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
