Re: MODEL 200 OIL FILTER
Posted by Mark Peters on April 19, 2009 at 17:02:39 from (66.222.7.31):
In Reply to: MODEL 200 OIL FILTER posted by bluegrasmtns on April 19, 2009 at 16:13:13:
Clint S said: (quoted from post at 18:13:13 04/19/09) OK I was not paying attention. ON my model 200 which way does the oil filter go on. There is a shorter stubier extension and a longer one off each end of the filter. I am pretty sure the longer one goes in the housing (down) and the short one points up. Thanks Clint
The larger diameter flange goes down and the smaller diameter flange goes up.
