Re: 584 PTO WON'T ENGAGE
Posted by JimB2 on April 19, 2009 at 17:05:48 from (99.240.236.11):
In Reply to: 584 PTO WON'T ENGAGE posted by Steve C. on April 19, 2009 at 14:49:07:
Hi Steve, usually the problem is the valve stem is stuck in the MCV valve or the actuating mechanism is siezed. Use your favorite penetrating oil and spray all the moving parts.
If it is a stuck valve stem there is a rubber boot that can be carefully pried up and penetrating oil sprayed into the top of the valve. The valve stem goes thru a guide that can become siezed.
JimB
