Re: combine motor in 560
Posted by Larry B 1486 on April 19, 2009 at 17:16:10 from (67.142.161.32):
In Reply to: combine motor in 560 posted by J Thomas on April 19, 2009 at 06:09:59:
The 301 motor out of a combine the best I can remember was rated 74 hp at 2250 rpm. It is the same motor as the D 282 but the 301 did not have sleeves and was used only on combines. I know some have been put in some 706's but you can't run a 560 at that high of rpm's as a 706 because of the way it is geared. The other thing is the 560 transmission and rear end if you are going to use that much power on the drawbar WON'T hold up. I know first hand
