Re: Farmall 300 hydraulics
Posted by D Slater on April 19, 2009 at 17:25:38 from (71.182.24.12):
In Reply to: Farmall 300 hydraulics posted by Bkpigs on April 19, 2009 at 14:48:08:
2 point hitches raised lever forward and lowered lever back. If your 2 point hookup has a check valve (a extra block on outside of block at the end of steel lines bolted to right rear of battery box) I don"t think the hitch will lower unless valve is set to double acting.
If you hook the fast hitch cylinder lines in the 2 outlets at end of steel lines, you can change lift and lower direction and type. But the check valve keeps pressure from leaking back through the control valve to keep the load from leaking off.
