Posted by CNKS on April 19, 2009 at 17:44:15 from (216.144.104.128):
In Reply to: 300 clutch/TA posted by makin'hay on April 19, 2009 at 15:15:49:
Pull the access cover off under the tractor to reveal the clutch (in your case, be sure the engine is OFF) and look at the fingers and the clearance between the fingers and throwout bearing, should be 1/8-1/4 inch. Have someone push the clutch in and out if you can't reach it, and see what it does. Adjust both the clutch and TA to specs, that requires a manual, unless someone wants to walk you thru it. Basically it is adjusted so that the engine and TA clutches release at about the same time. If that does not work, you need a rebuilt engine clutch and/or the TA needs to be rebuilt. I don't know what the previous owner did, never heard of your situation.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
