You have to remove the lift all and then the main drive shaft coupling and the clutch shaft. When all that is out, you unbolt the bearing/holder assembly from the front of the transmission housing. The assembly, including the bearing holder, seal holder and the transmission input shaft will then slide out the front of the transmission. I can't recall if the gear will slide off over the pinion bearing or not, but I think you will have to remove the retainer bolt for the pinion bearing, remove the pinion bearing and then the 4/5 slider gear can be taken off and replaced. While you are in there, make sure to check the transmission input bearings for play and replace if needed and you might as well put a new shaft seal in as well.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
