Re: Re: Re: Re: 1466 oil cooler
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Larry24d on April 09, 2000 at 08:08:54 from (209.242.110.95):
In Reply to: Re: Re: Re: 1466 oil cooler posted by Bob on April 07, 2000 at 17:46:19:
one more suggestiion....if you decide to run it. drain the antifreeze...if you run it with antifreeze in the oil. You'll probably end up with a spun engine bearing...my guess is you'd be alot better off fixing it. Staight water will be a whole lot better on the engine bearings if you do run it with a little in the crankcase
Post A Followup
: Re: Re: Re: Re: Re: 1466 oil cooler
