Re: 1066/1466
Posted by Hugh MacKay on April 20, 2009 at 02:04:19 from (216.208.58.100):
In Reply to: Re: 1066/1466 posted by Owen Aaland on April 18, 2009 at 12:42:22:
Owen: Shortly after I bought my 1066 in 75, I guess the IH dealer figured I'd trade everything back to the old 300. Anyhow I often got oportunities to try new tractors, and yes I have to aggree with everything you say. Now my neighbor claimed if you add front drive and 24" tires to the 86 tractor that will smooth it out.
My own opinion is go articulated once you get much over 100 hp. You've then got a spot for 150 gallon fuel tank behind the articulation joint, the ride is superb, you do need a mirror for hitching, but you know something, once those implements got big hitching almost became a two man job. At least it was much faster with two.
