Re: Generator mounting
Posted by D Slater on April 20, 2009 at 06:40:53 from (71.182.24.12):
In Reply to: Re: Generator mounting posted by Mike CA on April 19, 2009 at 18:26:24:
Don't know any tricks. Sometimes they will just come off after nut is removed by holding pulley with the weight of generator hanginging just off work bench and striking end of shaft. That is taking a chance on messed up threads. On gas ones a bearing clamp type puller can be used on heavy inside part of pulley after taking set screw out if adjustable. On MD type a thin one in pulley grove works.
