The spark advance should ground the mag [at the mag: lever way up, maybe 1:00 facing it] when pulled way to the left, it sure doesn't hurt to trade a bit of motion to be on the safe side of turning it off - this wouldn't affect starting, only potentially a bit late at full operating RPM [where you'll have it to the right].
It'd be interesting to post a question on the best time frame and duration for seating the rings, and general break-in: probably get as many answers as # of members activly posting! :lol:
Probably somewhere between 20minutes and 20hours of light loads
(just driving it around I'm of the mindset of a few light trips around the yard [closer to the 20minutes or maybe an hour], at least one long enough to get some temp [at least 130's like a hot water faucet] in the radiator check it over, then a good load for an hour or two)
then give it a load of 1/2 to 3/4 rated
(plow, disk, thresher [if there are enough people and bundles to run an hour straight], or dyno or power-eater)
and get the radiator up to boiling [on water, might want a gauge if you already mixed antifreeze, no idea though of the right number - say 220 constant?] for an hour or better.
I've heard of just covering the radiator and driving it around good and warm, and even claims that quality rings will seat without working it - but logic to me seems that getting it to a solid operating temp and under load before the sleeves glaze is the best chance for the rings to seat. Of course, I wouldn't need to count toes, and maybe not even complete both hands, for the number of engines I've given new rings - so I'm probably over cautious.
For that first or second crank start every time, there are likely some sweet spots - but for starting a few cranks, unless wayyyy too late (like 45degrees back down the stroke), or early enough to kick (or the mag grounding yet in the start position: not the case if you have spark), you shouldn't need that much prescision there.
Same with priming fuel: I do like the cups to see if the carb is cooperating, else just choke for the first couple cranks (on 'loose' engines, I've often used Bob's trick of "mag off"-"choke on" first 4, choke off-mag on the next one, but seldom over a couple pulls with choke (and not even turning off the mag) with good compression) should be enough if the carb [and, of course, everything esle :lol: ] is cooperating.
Good luck! Hope you have more fun than frustration or fatiqued muscles. 8)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
