Re: slow cranking
Posted by Janicholson on April 20, 2009 at 08:16:30 from (199.17.6.128):
In Reply to: slow cranking posted by jdn on April 20, 2009 at 06:18:38:
The cables need to be much larger than automotive normal. OOgauge is needed, Soldered on connections. The typical #4 12volt cable will not spin them. The starter will draw 350 to 400 amps and that needs fat wires. If it draws more, and you have fat wires, The starter could be dragging internally. (this assumes that the timing is set correctly. JimN
