Re: Farmall 300 hydraulics
Posted by badaugherty on April 20, 2009 at 08:43:17 from (157.142.139.118):
In Reply to: Farmall 300 hydraulics posted by mkirsch on April 20, 2009 at 05:09:51:
mkirsch said: (quoted from post at 05:09:51 04/20/09) We're talking about ONE WAY OPERATION here.
Hydraulic fluid only comes out one port when the valves are in one-way mode.
You can't change which port the fluid comes out of on the tractor because they're connected with hard steel lines.
You can't make the lever work in the opposite direction by switching the hoses at the port because there is only one hose. He said this up front in the first post.
No offense meant here guys, but sheesh, try to read a little better.
I got that and I was adding to the same topic with my own issue? Should I have just started another topic? Sheesh, try to read a little better.
