Re: Farmall 300 hydraulics
Posted by pete 23 on April 20, 2009 at 10:53:55 from (173.87.1.12):
In Reply to: Farmall 300 hydraulics posted by Bkpigs on April 19, 2009 at 14:48:08:
My understanding of the original question was, are the levers working backwards, no they are not, you should raise implements and or hitch by moving lever forward. If you switch the hoses on the hitch cyl so hitch raises when you pull lever back, the one way check valve will not hold hitch up if it is equipped with the check valve.
