If it's the original, it will be a mushroom shaped button on top of a fairly cylindrical switch housing, mounted to a bracket on the side of the throttle lever on the steering support post. Should be two terminals on the bottom of it, one bringing in current, and the second running up to the coil. Button-up is the run position sending current to the coil. Button-down breaks the circuit to stop the motor.
If it's not the original, it could be anything for a single pole, single throw switch. Follow the wire back from the coil and see if you run into a switch of any sort somewhere.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
