Re: farmall super c rock shaft
Posted by P and R Pete on April 20, 2009 at 16:00:49 from (173.86.63.148):
In Reply to: farmall super c rock shaft posted by mitchfarmallsuperc on April 20, 2009 at 09:52:26:
Mitch, I'm going out on a limb for two reasons, first because I'm assuming you're talking about your hydraulics, and second because I don't know if a C is the same unit as a SA, so these pics might not apply at all.
This is my SA unit going back together.
third party image
That fork INSIDE the pillow block is actually part of the shaft, so the shaft has to go into that pillow block from the left.
third party image
Now here's where I'm not exactly sure of my memory, but I believe that left fork inside the left pillow block is one and the same piece with the left arm immediately outside the left pillow block, (the arrows labeled #1), and since it thus cannot be slid through a pillow block, that is the reason the left pillow block is SPLIT and the right isn't (see arrows labeled #2). The only arms that come off with the shaft-in-place are the right and the outer left, which are both driven from the right fork/shaft, and because those two arms are KEYED to the shaft. The arm and fork labeled #1 are one piece, unkeyed, and independent of the shaft, though they slide on it.
If we're talking about two entirely different things, well then, never mind! LOL! Just trying to help.
