[quote:15b94b2583]You said International, not Farmall -- there are differences
the dash panel should still lift out with some difficulty.
Screws are easy to break off[/quote:15b94b2583]
Thank you.
Yes, International. 460 Utility.
It does lift out with some difficulty.
Good way to put it. Not easily, but not really too hard.
Not all of the screws are easy to break off. :roll:
I couldn't get the screwdriver to stick good enough in the head to get a grip to break off the screw. I had a couple of screws that I was able to get a pair of vice grips on and get them screwed out. I did break off one screw. I ended up having to drill out one screw because I couldn't get the vicegrips to grip onto the dome head and the screwdriver slot wouldn't work.
Not really too bad. I did have some cranky when I got the panel screwed back in and started the engine and the throttle wouldn't slow the engine down. Found out I had to get the rod shoved back in the correct hole to get it to guide correctly. :oops:
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
