Re: cub hydrolic surging
Posted by EZ on April 21, 2009 at 08:07:12 from (165.115.113.207):
In Reply to: Re: cub hydrolic surging posted by James Rumph on April 21, 2009 at 03:37:57:
That "whining" noise could actually be a sign of a dirty screen or plugged orfice. Do you have a manual?
The screen protects the orfice from plugging up. I had a broken screen which allowed dirt to plug the orfice and the whining and vibrating of the tubes were evident.
On the head of the TC Unit there is a plug with a 1/4" square hole in it. Use a 1/4" ratchet to remove, then reach inside with a flat screw driver and thread out the orfice and screen ( 1 piece) and check it out for dirt. You should be able to blow air through it. The orfice is located in the center of the screwdriver slot.
This is how I fixed mine.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
