Re: Replacing Lift Arm Balls on a 3-Point Hitch
Posted by James22 on April 21, 2009 at 11:13:16 from (207.179.221.63):
In Reply to: Replacing Lift Arm Balls on a 3-Point Hitch posted by rumplestiltskin on April 21, 2009 at 09:21:56:
On newer tractors you simply cut off the entire left arm ball joint end and install new unit. And I asume you can do the same on a 350. New ones are available at ag supply stores and I assume thru YT. Need to match up size and angle (if any). Not a job for an amateur/occasional welder. I had mine replaced on the IH 4166 by a retired CAT welder and they came out great!
