Re: RustyFarmall Range trans cover
Posted by caterpillar guy on April 21, 2009 at 12:59:44 from (172.131.171.161):
In Reply to: RustyFarmall Range trans cover posted by TGIN on April 21, 2009 at 04:35:56:
Where are you at I can get it done rather cheaply if you can get the lid here. I"m in Owosso MI or call me 989 413 5684. I can also bore it with a drill bit in the drill press then fit the bushing to the hole. Well if you want that to shift like new again just change it over to a 56 series shifter did it on an 806 boy what an improvement.
To change it over is not that big of a job either.
