Re: Super M lifting pressure
Posted by Roy Ward on April 21, 2009 at 14:22:52 from (69.19.14.29):
In Reply to: Re: Super M lifting pressure posted by Harold hubbard on April 21, 2009 at 14:03:07:
You are right the 1209 needs a cylinder on the other side there is to much weight there to lift. You know that one cylinder is in a hell of a bind. I will be cutting a flat Hay Grazer field so for now I plan to just use cylinder blocks to set my cutting height and go. I only have 20 acres to cut and once I set the cutting height I guess I don't need to raise and lower it.
Thanks for your comments.
