Re: D358 engine crank question
Posted by the tractor vet on April 21, 2009 at 19:57:36 from (75.19.124.161):
In Reply to: D358 engine crank question posted by DaleCarter on April 21, 2009 at 19:11:50:
Yep there the same . Just how bad is the block and the crank. Myself i would see if ya could line bore the block and turn the crank. Now if down time comes into play then finding a complet engine in running order and all ya have to do is maybe change the ft timing cover and rear plate and a oil pan and pickup then that's the way to go and the swap could be done in a couple days .
