Re: Farmall M new mag running rough
Posted by ScottyHOMEy on April 22, 2009 at 07:33:51 from (71.241.208.90):
In Reply to: Farmall M new mag running rough posted by oppie_25 on April 22, 2009 at 07:12:25:
With the cap and internal cover off, check the shaft to see if it wobbles any, side-to-side, up-and-down, all around. Any significant wobble will throw off point gap and timing. Also can't hurt to check for an intermittent short/break in the insulation in the ground wire that runs to the switch (with switch in run position, check for continuity between the insulated stud on the mag and a known good ground), especially at places where it passes through retainer clips.
