Sounds like a spark timing issue. If the idle timing is wrong a smooth idle cannot be achieved.
With the engine warmed and idling, loosen the mag clamp bolts and turn the mag a little each way. Try to find the spot where the idle is smoothest then retighten the bolts.
Then I’d stick a timing light on the #1 plug and check where the running timing is. The manual says it should be 35 deg BTC – which gives good power and reasonable fuel economy under load. If you find it's not at 35 deg, suspect a problem with your new mag's impulse coupling not giving the right advance degrees in "run".
Incidentally variable advance is one of the key advantages of a distributor over a magneto: The distributor will vary spark timing to match RPM from idle (0 deg advance) to full governed speed (40 deg). A magneto OTOH has only 2 timing settings: “Crank” (0 deg at cranking speed; impulse is engaged) and “run” (35 deg advance at all RPMs faster than cranking speed).
Unfortunately the non-adjustable 35 deg “run” setting means you may must compromise the timing setting between the smoothest idle and the best power at full RPM/load.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
