There are two possible sources, the intake valve, or the rings on that cylinder. Both are equally likely. If it is not smoking much, I might consider running it the way it is. Until it fouls the plug enough to misfire on that cylinder continually, it will be OK. A hotter plug in that cylinder alone might assist in reducing fouling. If you use the tractor hard, it might be OK as is. Good luck, JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
