Re: John T, 140 needs attent
Posted by Hugh MacKay on April 22, 2009 at 19:05:55 from (216.208.58.190):
In Reply to: Re: John T, 140 needs attent posted by Tom McArdle on April 22, 2009 at 18:06:38:
Tom: Get yourself a test light and check out every wire associated with ign and charging. I wish we had someone more knowledgable explain that resistance unit. My question is it the same as a resistor that reduces voltage to the coil. That is another item you can check with the test light, where current goes from the resistance unit. Those wires should all be color coded.
