Posted by ih560 on April 22, 2009 at 19:31:39 from (67.131.50.233):
In Reply to: Water in the oil! posted by Mac DeBusk on April 22, 2009 at 14:40:02:
Mac DeBusk said: (quoted from post at 14:40:02 04/22/09) I've been working on an old IH Utility 340 gasoline, and I just finished rebuilding the engine where it threw a rod. Part of the job was removing and reinstalling the piston sleeves. Now my number 2 sleeve leaks water. There's no gasket or seal at the bottom of the sleeve. How do I fix the leak?
When you rebuilt the engine did you buy an overhaul kit? If so the new kit should have had new O-rings included. The o-ring can be hard to see in low light but if you shine a flashlight down in there you will see the o- ring located where the bottom of the sleeve slides into the block. The o-ring is located in a groove in the block (like stated) and not on the sleeve. The o-ring is probably 1/4" or so thick and will be mashed flat in the groove.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
