Posted by mkirsch on April 23, 2009 at 08:28:42 from (64.80.108.55):
In Reply to: Replacing the 400 TA posted by J.Horn on April 22, 2009 at 14:47:48:
If you're eliminating the TA out of some misguided notion that it is a "weak link" or "unreliable" then you should reconsider.
It's very likely that the TA in your tractor is original. That means it lasted over 50 years through the hardest work the tractor will ever do in its lifetime.
It's also very likely that you will be able to fix the problem by replacing the ramp and rollers, parts which are readily available and not much more expensive than the TA eliminator kit.
Replace or repair the TA, and it will outlast you at this stage of the game. It will make the tractor much more valuable down the road too.
If you still insist, you could simply drain the oil and weld the TA solid. Lots cheaper than the TA kit and you don't even have to tear the tractor down. Just make sure there are no gas leaks. Maybe wrap the gas tank in a welding blanket...
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
