definately go with the new cam gear, they sell the super m gear on this site for about 139.00. with the 400 live pump, you need to cut off the small gear that drives the hourmeter. if you dont want to change the front engine cover you can plug and redrill the top two holes, as was done with the m+w live pump conversion kits. you run a bolt in the top two holes, cut them off flush and file them flat. then remount the pump using the bottom two bolts, the redrill and tap the top two holes. the drill will cut thru about half of the top two bolts. when i did my 48 m, i drilled and put heli coils in. works pretty good. my m has the hydraulic resevoir in the body of the loader, but you can use the belly pump. the m+w kit had a plate in it, you would remove the belly pump out of the unit, and bolt up the plate, giving you some extra capacity. here are a couple pics of the belly pump cover
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
