Re: Hydraulic valves
Posted by mkirsch on April 23, 2009 at 13:35:24 from (64.80.108.55):
In Reply to: Hydraulic valves posted by Clean John on April 23, 2009 at 10:40:29:
The single-action loader cylinders are not built to take pressure on the top side. If you try, you will only get another snoot full of oil.
Here's what you do:
1. Run a hose from one valve's work port to a T, then to the two lift cylinders.
2. Run a hose from the same valve's other work port to a return on your hydraulic reservoir.
This way it will just pump the oil straight back into the reservoir when you let the loader back down.
This also leaves your second valve available for other things like a hydraulic dump bucket.
