Re: B 275 wiring and full restore at some point
Posted by mk1g on April 23, 2009 at 17:41:43 from (92.10.64.235):
In Reply to: B 275 wiring and full restore at some point posted by jdemaris on April 23, 2009 at 12:23:45:
jdemaris said: (quoted from post at 12:23:45 04/23/09) Gas or diesel, and what exactly do you want to know? It's basically a British/Indian tractor and many were made by Mahindra, who had a joint-venture with IH.
Very rugged tractor and pretty easy to work on. A few odd-ball things about it you might need to know.
its a diesel mate need to know for now the aultinator wiring diagrams pics anything :) ault was tested yeserday and all is good new bushs and connections there is 3 terminal on ault wat is wat tho and connects to wer??
fitted alut didnt wire it up and started tractor tested terminals and no power coming out of any hmmmm confused!!!
mainly the problem is when tractor is left for a day or 2 battery is flat completely battery is ok charged and tested any info thanks
from a guy who knows little :)
