Re: 806 Oil in Coolant
Posted by the tractor vet on April 23, 2009 at 18:41:20 from (75.19.124.161):
In Reply to: Re: 806 Oil in Coolant posted by chadd on April 23, 2009 at 18:29:34:
Well , I know that at 5000 hours if they are true then she maybe in need of a valve adjustment . Now as to the oil in the rad . are you sure that it is oil and not carbon . Do you see any leakage on the outside of the head. And really the only place oil can get into the rad is the oil cooler . Now if she is getting ready to puk and head gskt then they can under load start to push compression into the rad. As to it standing FIRE under load YEP they will do that . Ya should see mine on the bagger at night she will show ya fire and smoke . and they will burn the paint off the muffler . The bad thing here is we can talk about this and that but i can not see the tractor and check it out in person . So there can be a lot of could be's . And since nobody has chipped into the KITTY to get me some long range transportation at high speed unless your with in a reasonable distance all we can do is talk about it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
