Re: 140 won't charge/help John T
Posted by Bob M on April 24, 2009 at 08:13:16 from (151.190.254.108):
In Reply to: Re: 140 won't charge/help John T posted by Janicholson on April 24, 2009 at 07:21:15:
third party image
Thanks for the alternator info Jim! (I'm not familiar with the 140 family...)
Here's how to check the alternator on the tractor:
1 - Check resting voltage: Pull the aux (2 wire) connector from the alternator. With the ignition OFF you should see the following voltages to ground:
BAT - 12
Aux #1 - 0
Aux #2 - 12
2 - CCheck "key on" voltage: With the aux plug still removed, turn the ignition on but don't start the engine. You should see 12 volts at both Aux #1 and #2.
If you don't get the above STOP. Either the wiring is messed up or the alternator idiot light has burned out. It won't charge until the problem is found and fixed.
If the above checks out plug the aux terminal back in. Now start the engine, run it up to full throttle for a moment then set throttle back to around 1/3 (1,000 RPM or so). Then:
3 - Take the voltage reading at the alternator BAT terminal. It should be 14 - 14.5 volts. If it's less the problem is the alternator.
4 - To determine whether the internal regulator is the problem, find the regulator shorting tab inside the "D" shaped hole on back of the alternator (photo). With the engine still running at about 1/3 take a small screwdriver touch the tip to the metal tab inside the hole. Now ground the screwdriver shank against the side of the hole. If the voltage jumps to 14 or more with the tab grounded it means the internal regulator is shot. However if still no change the alterator has other problems.
Good luck!
