Re: power steering on 1951 H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Les Repair on April 09, 2000 at 16:58:46 from (206.28.174.165):
In Reply to: power steering on 1951 H posted by john H on April 09, 2000 at 15:41:29:
You can't use your lift all pump. Probably the simplest way is with a belt driven car powersteering pump.
Post A Followup
: Re: Re: power steering on 1951 H
