Pull the coil wire out of the center tower on the distributor cap, attach a clean spark plug on the end of the wire then lay the plug on top of the coil (or fix the coil wire so the end’s ¼” or so from grounded metal). Now manually work the points open a few times with the ignition on. You should get a nice, fat spark each time the points open.
If you get a good spark most likely the distributor is out of time. Retiming it should get the tractor running.
However if you DON’T get a spark, suspect a bad coil or (long shot possibilities…) a failed condenser or bad coil wire.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
