Re: IH Sickle-bar mower type?
Posted by ScottyHOMEy on April 24, 2009 at 16:00:39 from (70.105.230.77):
In Reply to: IH Sickle-bar mower type? posted by mb58 on April 24, 2009 at 07:43:53:
There may be others, I've got a Model 21 and I know there was a 24, both of the pitman arm type, and both of which are mounted on a frame that bolts up to the brackets on the axle housing.
