Re: 384 International Lift problems
Posted by JimB2 on April 24, 2009 at 17:28:24 from (99.240.236.11):
In Reply to: 384 International Lift problems posted by Eve on April 24, 2009 at 17:06:02:
Hi Eve, make sure draft control lever is fully forward. There are two valves at the front of the seat, left one is push & turn, this one controls flow rate of hydraulic oil to 3pt. In is 3 GPM, out is 6 GPM. The left valve controls the direction of hydraulic oil flow and is controlled by 3pt lever, open hydraulic oil goes to 3pt, closed hydraulic oil goes to remote outlet, large plug at front of seat. There is another plug at front of seat and it has a filter behind it. There is also a filter on the suction line at the outlet of hydraulic reservoir.
JimB
