Re: diesel SMOKE
Posted by Janicholson on April 24, 2009 at 19:44:17 from (208.54.90.35):
In Reply to: diesel SMOKE posted by William Chavis on April 24, 2009 at 19:13:48:
If one cylinder is not firing, there will be vast white smoke. If it is not firing due to a blown piston there will be unbelievable smoke.
A compression check is needed, as is other diagnosis. Abything from a bad injector, to a wrecked engine is possible. JimN
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
