Re: Re: IH300 Utility IPTO problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Les Repair on April 09, 2000 at 17:10:20 from (206.28.174.165):
In Reply to: Re: IH300 Utility IPTO problem posted by PD on April 09, 2000 at 14:50:32:
The unit is simple to adjust. After you remove the oblong metel cover held on with a screw, you will see two adjusting screws with jam nuts which take a 3/4 wrench. The front screw sets the power band and the rear one adjusts the brake. With the IPTO lever floating between off and on, loosen the front jam nut and turn the adjusting screw down several turns and try the tractor under load. Adjust it again if necessary. If you can't make it work by doing this you will have to take the unit apart. Its not a real bad project. 515 847 2731
Post A Followup
: Re: Re: Re: IH300 Utility IPTO problem
