Posted by Bob O2 Martin on April 25, 2009 at 13:17:36 from (69.66.16.186):
In Reply to: Farmall H starting posted by Lee from IN on April 25, 2009 at 13:01:57:
If you have fuel in the carb and the jets are clear, think terms of the ignition = coil/points/condenser/resistor. Something there may be heating up and cutting your spark level.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
