Re: float level for F-14 carb
Posted by lil mac on April 25, 2009 at 18:22:43 from (76.29.129.96):
In Reply to: float level for F-14 carb posted by lil mac on April 25, 2009 at 07:20:43:
Johm, are you talking about an extra gasket between the carb and manifold or between the two halves of the carb?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
