distributor change over
Posted by tim lucas on April 25, 2009 at 20:43:53 from (208.104.36.152):
I have a 1941 'A' and the screw to hold the points gap is stripped out---I need to change to the new type---What is the best way, and if possibe the, cheapest way to do this? And do I need to set the timning by the by the flywheel mark?------Will the new type 'snap' when you turn it?---thanks for any info
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
