I would check the points if you are not getting fire, they may look fine but could still not be functioning properly.
Also if it is a magneto just unhook the small wire (probably 18 ga or smaller) from the side of the mag that goes to the condensor and leave it off to take the switch out of the equation. If it is a distributor just run a hot wire straight from the battery to the positive side of the coil to make sure that is getting power and again to take the switch and old cracked wiring out of the equaion. If you are still not getting spark after that then I would purchase a new cap, rotor, wires and plugs, which you will probably need to purchase sooner or later anyway.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
